It is currently Sat Jul 19, 2025 2:12 pm
PostPosted: Fri Feb 12, 2016 4:36 am
First name: george
Last Name: s
Shellac French polished, is by far my favorite finish. One problem I am facing is when I want to stain a piece darker, the French polish process is rubbing out the stain. Has anyone tried tinting shellac, I want to go darker than Garnet shellac. If so, what did you use for the tint? Also, are there better ways to accomplish this? Thanks.
GS
PostPosted: Fri Feb 12, 2016 7:34 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I have used Behlens Solar lux to tint shellac with good results. I would thin k any alcohol based aniline dye would also work.
Brian
PostPosted: Fri Feb 12, 2016 8:45 am
Trans tint from Stew Mac works
PostPosted: Fri Feb 12, 2016 1:19 pm
Country: Ireland
I've dyed and sprayed shellac with success.
PostPosted: Fri Feb 12, 2016 2:59 pm
I've used the Stew Mac stuff too, works great.
PostPosted: Fri Feb 12, 2016 3:03 pm
First name: george
Last Name: s
Thanks fellows, I'll order some up and see how it goes. I am guessing a pitfall to watch out for is uneven coat. I learned this French polishing light wood with garnet. I ended up with darker areas that I needed to sand out. I haven't had much luck with spraying shellac, and I kind of like the trance-like state I go into when using a pad :-)
Regards,
GS
PostPosted: Fri Feb 12, 2016 4:02 pm
I never tried spraying it before but I like to brush on the first two coats to get a head start on the FP process. Are you restoring something though? Or is this a fresh build or refinish that you are trying to match color?
PostPosted: Sat Feb 13, 2016 6:00 am
First name: george
Last Name: s
jfmckenna ,
It is a restore / learning project. I got this pile of parts to try a few things out. I had an Oahu K71 that someone had tried to convert to a round neck using what looked like A pen knife, so I got this Oahu to practice neck carving with a spoke shave. It came out as a nice C shape, so I had the nerve to fix the K71, which came out great. A friend mentioned he wanted a starter guitar for his son, so I told him if I could put this birch-ie back together and it came out okay he cold have it.
I think this is from the 1930's. It is a 13" birch Oahu, so probably never great. The top and back looked like potato chips. I was able to flatten the back but the top was cracked in many places and generally in bad shape, so I took the opportunity to make a new top. I braced it like an x-braced Stahl (laminated x and tone bars). Unfortunately, the low tack tape I used to put the binding on was still a little too tacky so I blew what was left of the back finish, so I stripped it and intend to stain then tint it very dark.oops_sign
Not a preservation project at all, just an attempt to try some ideas out on something that otherwise world have gone in the scrap bin.
Here is a work in progress shot, cedar top and binding and some amber shellac applied to the top:
If it comes out okay, I am going to donate it to a friend as a starter guitar.
Thanks for the tips everyone.
Regards,
GS
PostPosted: Sat Feb 13, 2016 10:17 am
First name: Allan
Last Name: Bacon
Jeez, I love rescue stories. Good for you!
PostPosted: Sat Feb 13, 2016 1:54 pm
First name: george
Last Name: s
I know how you feel. I loved reading JF's S.S. Stewart thread and the recent icr L-50 thread. Brian has a recent ES 125 or 225 cliff hanger that was fun to watch. They are like soap operas to me, but they always have a happy ending. When someone starts a new one I always think, humm, this one looks good, make some popcorn, and ponder how all the repairs will get done
PostPosted: Sun Feb 14, 2016 9:00 am
That's great! The top looks awesome too. Rescue stories are the best. You are kind of like a surgeon bringing life back to the patient :D
These users thanked the author jfmckenna for the post: gxs (Mon Feb 15, 2016 3:48 am)
PostPosted: Tue Feb 16, 2016 7:15 pm
First name: george
Last Name: s
This worked great. Thanks gang Have a look. The back photo is a little bleached by the flash, it is a bit darker black cherry and looks great in room light. Here are a few pics.
Looks like a poplar neck.
Birch back.
Thanks again.
GS
PostPosted: Fri Mar 11, 2016 4:10 am
First name: george
Last Name: s
I'm letting the shellac harden up and I'll polish it in a few weeks and then it is done. It sounds pretty nice for a 13". I braced the top mostly following the plans I have for a Stahl #6. I laminated with a strip of ebony between two pieces of cedar left over from the top to make the braces. Thanks for the tips.
GS
PostPosted: Tue Mar 15, 2016 9:51 am
Sweet! Now play it till your fingers bleed!
These users thanked the author jfmckenna for the post: gxs (Wed Mar 16, 2016 1:24 am)
cron
